1995 Pontiac Bonneville shifting out of park
1995 PONTIAC BONNEVILLE
GOTTIBME
1995 Pontiac Bonneville 6 cyl 190,00 miles
Sometimes the car has a hard time getting it out of park,So far I am guessing a sensor,but other then that then Im not sure,anyway that was my queston
Sep 17, 2010 at 5:49 AM
WRENCHTECH
  • 20,761 POSTS
That would be called the shift interlock feature. It operates on the same circuit as the brake lights so the first thing you want to do is to make sure the brake lights are working when this problem is present. If the brake lights are working, that proves the circuit is good up to that point, then you'll have to get to the solenoid in the console. Disassemble as much as you have to to access the solenoid near the shifting mechanism. Us a 12v test light to test for power coming and going at the solenoid when the brake is applied. If power is arriving and switching and the solenoid is not triggering, the solenoid is bad and will have to be replaced.
Sep 17, 2010 at 6:22 AM
