1990 Pontiac Bonneville about not starting right away
JOHNATHONGREEN26
MEMBER
1990 PONTIAC BONNEVILLE
6 CYL
FWD
AUTOMATIC
153,220 MILES
What would it be if the car does not start up right away
Wednesday, March 17th, 2010 AT 1:38 PM
MECHANIC
I need you to check fuel pressure drop off. If the pressure drops, it takes a few seconds to rebuild. Here is a how to for checking pressure. When you turn the key off, watch the gauge. It should hold pressure for a while and then slowly go down to a point and stop.
