1997 Plymouth Voyager Fuel Pump Relay Location
METHODICALLY289
Just changed the fuel filter, and still having issues. The van wont start. It has power, and a full tank. The filter was just changed, so I'm trying to fuel relay sensor. Only problem is I can't locate it. Any ideas?
Jan 9, 2007 at 6:12 AM
CARUNDELL
  • 602 POSTS
[quote:a304823cd3="methodically289"]Just changed the fuel filter, and still having issues. The van wont start. It has power, and a full tank. The filter was just changed, so I'm trying to fuel relay sensor. Only problem is I can't locate it. Any ideas?[/quote:a304823cd3]
Hey method,
There is no "fuel relay sensor" ..... but the fuel pump relay is located underhood in the electrical center, should be next to or close to the asd relay. Let us know!
Chris
Jan 9, 2007 at 6:53 AM
Suggested Repair
There is no fuel relay sensor. Locate the fuel pump relay in the underhood electrical center, next to or near the ASD relay.
Conversation Summary
The owner of a 1997 Plymouth Grand Voyager says the van will not start after a fuel filter change and asks where the fuel relay sensor is. The expert explains there is no fuel relay sensor and that the fuel pump relay is in the underhood electrical center near the ASD relay.
