1994 Plymouth Voyager Dies After Miles
1994 ALL OTHER MAKES ALL OTHER MODELS
TAG3969
I have trouble keeping my van running, it starts fine and will run for a few miles then just quit, I need to wait 10 or 15 minutes and it will start again but not run for long..I have replaced the plugs, fuel filter and a new battery any suggestions?
Jul 12, 2006 at 4:05 PM
CARAVANOGRE67
  • 22 POSTS
you should get your fuel pump checked for the amount of psi it is putting out some motors need 35 to 60 pounds of fuel pressure to run i just looked it up and you need 39 psi to run that motor. You should also check to see if your fuel pump is shot or not
Aug 2, 2006 at 4:45 PM
Suggested Repair
Check fuel pump output pressure. The 3.3 engine needs about 39 psi; test whether the fuel pump is failing.
Conversation Summary
The owner of a 1994 Voyager 3.3 says it starts fine, runs a few miles, then quits, and will restart after 10 to 15 minutes but not run long. Plugs, the fuel filter, and the battery were already replaced. The expert advises checking fuel pump pressure, noting about 39 psi is required, and determining whether the pump has failed.
