92 Cambry. 200,000 miles LE 4 door
1992 ALL OTHER MAKES ALL OTHER MODELS
AGILLES901
I am having starting problems. The mechanic change inigition but the still won't turn over. We put gas in the carb and no luck. I can't seem to correct this?
is there a simple reason? like blown fuse or fuel filter stopped up.
Fuel pump is ok, the motor just keeps turning over and will not start
thanks
Apr 26, 2007 at 8:15 AM
  • 75,988 POSTS
[quote:ad045c5d46="agilles901"]I am having starting problems. The mechanic change inigition but the still won't turn over. We put gas in the carb and no luck. I can't seem to correct this?
thanks[/quote:ad045c5d46]
Look for spark-last major tune-up? could be a coil,ignition fuse,distributor pick-up and ignitor.
Apr 26, 2007 at 9:02 AM
AGILLES901
thanks, very frustratiing. we did change ignitor now looking at computer but will try first
Apr 26, 2007 at 9:06 AM
  • 75,988 POSTS
The mechanic change ignition but the still won't turn over. We put gas in the carb and no luck. I can't seem to correct this?
It sounds like ignition problem-it should be able to combust when you prime it.
Things to check
1.Confirm power to the coil and ignitor, the coil primary and secondary resistances
2. check the pick-ups and signal generator gaps in the distributor
NOTE: If the computer don't see the Ne and G signals from the distributor, it will not give the Igt signal from the trigger circuit in the computer to the ignitor to fire the coil-therefore no spark will occur.
Toys got some weird ignition system set up. I get confuse sometimes whether it would be a ESA/VAST etc.
Is the ignition fuse okay?
Hope this helps -Good Luck
Apr 26, 2007 at 11:21 AM
