engine oil warning light
PLYMOUTH VOYAGER
SHITFIRE
I have a 1999 voyager w/92000 miles. It has a 2.4, 4cyl. engine. The oil warning light comes on and dings rapidly unless the vehicle is in motion or the r.p.m.s are up. The oil is full. What could this be?
Nov 29, 2007 at 3:48 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Hi there,
You best have an oil pressure test done with a master gauge, this will give a true indication as to the oil pressure. If still low, it could be a number of things from a faulty pressure relief valve to worn bearings. Get the oil pressure tested first and re post results if you want more information.
Mark (mhpautos)
Nov 29, 2007 at 5:03 PM
