Check Engine Light Flashing
OLERED67
  • PLYMOUTH VOYAGER
1990
Plymouth Voyager
2.2L 4 Cylinder
185,000 miles
The Check Engine light is flashing in a definite repeating pattern. 1, 2, 3, 1, 5. Is this some sort of code for a specific problem? And if so, what?
Wednesday, March 7th, 2007 AT 8:29 AM
MERLIN2021
  • 17,250 POSTS
To check the codes turn the key on, off, on, off, on
The computer will then flash the codes at you.
A cod 22 for example will be 2 flashes followed by a pause then 2 more flashes. Count em write em down and post em.
Tuesday, March 27th, 2007 AT 3:06 PM
