2000 Plymouth Voyager Air Bag light and Cruise control
2000 PLYMOUTH VOYAGER
145,000 MILES • 6 CYL • FWD • AUTOMATIC
LEXI
I turned a corner and my air bag light came on. It turned off after about 5 minutes. When I turned the car on the light came on agian and hasnt shut off, now my cruise control won't work and my horn won't work either. I know that there was a recall on the clockspring in the hub of the wheel. Could this be related to that? If not, How can I fix it?
Feb 8, 2009 at 3:52 PM
RPTASIUK
  • 7 POSTS
You are correct. It is the clock spring. There has been a life-time recall on this problem; you may want to contact Chrysler direclty first. If you find trying to get it done on recall is to troublesome, it is not an expensive repair.
Sep 27, 2009 at 11:20 AM
