1999 Plymouth Voyager TURN SIGNALS AND HAZARDS
1999 PLYMOUTH VOYAGER
159,000 MILES • 6 CYL • 2WD • AUTOMATIC
TED10
The turn signals and the Hazard flashers went out on my '99 Plymouth Voyager. All the turn signals went out completely, they don't work at all. Same with the flashers. I changed the flashing unit, twice, nothing. Took the switch out and apart, it seems fine, all the other components of the switch continued to work after I put it back together. I checked the wire harnesses as best I could. Could it be the Body Computer affecting just these elements? There are no other electronic "ghosts".
Apr 11, 2010 at 11:32 AM
Hi ted10, Welcome to 2carpros and TY for the donation.
If its not coming from the flasher its either the BCM or the turn and hazard switch ground side G206 located on center of dash
Apr 12, 2010 at 12:39 PM
