My van started making horrible noise in the dash behind the glove compartment. So i looked into it and i found out the heater blower motor was making the noise and i went to the junk yard and they sold me a blower motor out a 2000 voyager that they assured me was the same. It installed exactly as the old one did, the screw holes all lined up atleast. So when install was complete, i plugged the wire harness back together and turned the heat on and nothing comes out now, not even a sound or humm. Any guess, maybe a shorted out relay switch or fuse? I looked at the fuse panel and i am not sure there is even a het/ac fuse unless its under the hood or something?? Thanks in advance, this is my only vehicle to drive around my four kids all at once. And i am not in any financial position to replace this van.
Feb 28, 2008 at 8:43 AM
