1998 Plymouth Voyager Front Wheel Drive Automatic 189500 miles
The heater does not work and it's winter in Michigan! I flushed the heater core and it's clear and clean as are the lines. The heater control use to work when I would move it back and forth from hot to cold. Now it only blows cold air. By the way, A/C stopped working 5 years ago. Is this an electrical problem with the control or is there a sensor device I need to replace? I did replace the thermostat 6 years ago could that be the cause of problem?
Thanks for your assistance
Patrick Hughes
SPONSORED LINKS
Saturday, December 1st, 2007 AT 1:30 PM
