1997 Plymouth Voyager Windshield Wipers
ARIKAMORROW
  • 1997 PLYMOUTH VOYAGER
  • 4 CYL
  • 126,000 MILES
When I turn on my windshield wipers, they don't move. There is no sound and they will work every now and then. I just got the motor replaced and they were working fine. Now they go when they want to. Is this a fuse problem?
Saturday, November 29th, 2008 AT 11:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Fuse simply lets electric current run through wires so this would not be the problem.
It sounds like there is a short in the wiring. Test wiring from motor and ensure that wires are well insulated and no bare spots that could cause short circuits.
Saturday, November 29th, 2008 AT 11:50 PM
ZACKMAN
  • 4,202 POSTS
In your power distribution center under the hood, there are two relays controlling the wiper operation. Try swapping them with similar relays you may have in the box.
Tuesday, December 2nd, 2008 AT 11:10 PM
PBLECHAR
  • 6 POSTS
If the wire from the stalk mounted wiper switch to the Body control module develops a poor connection, it can cause the wipers to sweep "by themselves". This is because Chrylser used a method of determining the time interval between sweeps based upon resistance and an open circuit will look like high resistance and cause a sweep. Push and tug gently on the wire leads under the steeing column near the stalk switch with the car on and NOT MOVING. See if something then changes.
Paul in Boston. Good luck, this is tricky
Tuesday, June 9th, 2009 AT 12:00 PM
