1996 Plymouth Voyager wiper motor arm assembly
MAVS_FAN24
  • 1996 PLYMOUTH VOYAGER
1996 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
What is the reset position for the windshield wiper arm assembly on a 1996 plymouth voyager when attaching a new wiper motor? The old motor was bad and would not go to the reset positon, hence no reference to position the arm assembly with the new motor.
Monday, November 3rd, 2008 AT 9:59 AM
RACEFAN966
  • 5,029 POSTS
I do not follow what you mean there is no reset button for the wipers. If you replaced the wiper motor and it will not park the wipers in the right spot then you hooked it up in the wrong possition at the motor. So what you need to do it unhook the wipers from the motor and turn the motor on and off again this will park the wiper motor. Then put the wipers in the right possition on the window and then hook it up at the motor and that should put it where it belongs.
Monday, November 3rd, 2008 AT 4:32 PM
