1997 Plymouth Voyager Door Lock/Latch
1997 PLYMOUTH VOYAGER
199,000 MILES • 4 CYL • FWD • AUTOMATIC
ZEBEYANA
The driver's door seems to not be closing properly. There is a "give" to it if/when I "bump" against it. Also, when driving, the door ajar alarm chimes, the interior lights flash, and the locks engage. It varies on how often this happens, mostly around turns, on rough patches, and it can be caused "on purpose" by bumping against the door. What I need to know is if it is a physical, mechanical problem, like a latch or part that can be personally replaced or if it is most likely a computer/electrical problem that needs a professional.
Mar 20, 2009 at 8:24 AM
MERLIN2021
  • 17,250 POSTS
If the door itself is moving, then either the latch needs to be lubed, or the stiker needs to be adjusted, by loosening and moving it inward, then tightening it up. Striker is where the latch catches...
Mar 20, 2009 at 8:47 AM
