1996 Plymouth Voyager Noise
SILVIOG13
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 117,000 MILES
When I turn the van on it makes a loud rattling noise. It continues when driving. The van does not over heat and the transmission is fine. It sounds as if a belt is loose.
Monday, January 4th, 2010 AT 9:08 AM
  • 109,885 POSTS
What I want you to do first is take a rubber mallot and tap on the exhaust system. Usually a loose heat shield or catylatic converter will cause a rattle.
Let me know what you find.
Monday, January 4th, 2010 AT 2:04 PM
SILVIOG13
Ok this morning the sound just poured out from the front wheel wells. When driving the noise is louder when I accelerate. I don't think it has anything to do with the exhaust.
Tuesday, January 5th, 2010 AT 6:21 AM
  • 109,885 POSTS
If it is worse when you accellerate, then it could be a belt. Was it a squealing sound?
Monday, January 11th, 2010 AT 8:18 AM
SILVIOG13
After further review I looked under the hood and saw some metal filings near the fly wheels. I could not see what was grinding. Any ideas.
Monday, January 11th, 2010 AT 9:30 AM
