1993 Plymouth Voyager van over heating
1993 PLYMOUTH VOYAGER
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
TAMMYDOVO
i have replaced head gasket,valve cover gasket, belts, spark plugs water pump, thermostate, and van is still running hot, also i have to keep putting water in the water holder please help thank you
Jun 30, 2010 at 3:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if coolant is leaking then either it is being burnt or is simply leaking out. is there any white smoke out of exhaust? the cylinder head itself may be cracked. could also be faulty heater core.
Jun 30, 2010 at 3:46 AM
TAMMYDOVO
no white smoke and they said the head was good when they replaced the gasket, also the van is not overheating but the meter in the van just stays at hot and runs out of coolent everyday
Jun 30, 2010 at 3:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the coolant tank, it may be cracked and leaking or the low coolant level sensor/switch on teh coolant tank may be leaking .
Jun 30, 2010 at 3:55 AM
