1996 Plymouth Voyager
JORDANP80
  • 1996 PLYMOUTH VOYAGER
Engine Cooling problem
1996 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
my voyager is leaking coolant, I have been trying to locate where the leak is coming from and the only place I have noticed is on the passenger side back side of the engine, and it only leaks when the air conditioner is on
Monday, July 12th, 2010 AT 5:41 PM
JALOPYPAPA
  • 467 POSTS
Heater hoses are near there, but so is the condensate drain for your A/C evaporator, which is the only thing that would be dripping only when the A/C is on. You need to make sure it's coolant and not plain water, and if the former, exactly where it's coming from.
Thursday, July 15th, 2010 AT 1:25 PM
