1996 Plymouth Voyager no spark
185,000 MILES • 6 CYL • FWD • AUTOMATIC
WWILL84
my van has no spark sometimes it starts to start
so like a dummy i put new coil pack crank shaft sensor cam shaft sensor and it still didnt start had a fuses checked and i replaced the pcm with one from the salvage yard and it started up and ran fine but when i shut it down for more than a couple of mins
it would no longer start but the junk yard computer was not the right one but i could get the car running but i had to hold the gas down and it run like crap
so i went and bought new pcm and it is like it was with my orginal pcm will not start at all just ever one in a while it want to all most start not sure what it is but maybe you can point me in the right direction
I completely out of money ive barrowld all the money from friends and family or i would donate to you. and i will donate when im on my feet again guranted.
Apr 28, 2010 at 12:19 PM
BMRFIXIT
  • 19,053 POSTS
What do you have for engine size?
Ok let’s try few things here
With key on do you have a check engine light on?
You should
Try and crank the engine does the light go out?
Remove air intake and access the throttle body and use a starting fluid spray in the throttle place the hose back try to start does it start? and then stall!
Try and scan for codes
Apr 29, 2010 at 9:41 AM
ALLENSCHEEL
  • 11 POSTS
have you checked the icm the ignition control moduel or the fuses under the dash board there should be a fuse called ignition feeder
Sep 23, 2010 at 1:29 PM
