1996 Plymouth Voyager drain plug for radiator
1996 PLYMOUTH VOYAGER
110,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHN DICOSTANZO SR
i was getting ready to drain the anti freeze and flush system . i turned the drain plug about 1/2 to 3/4 turn and it fell out . its not broken or anything but i cant seem to get it back in . is there a trick to getting it back in . thank you
Jun 4, 2009 at 6:38 PM
JALOPYPAPA
  • 467 POSTS
some plugs have a sort of anchor attached to the water side and tabs inside to prevent them from dropping out. If that's the obstruction, you may need to jiggle it a bit as you insert it. If the problem is that the O-ring on the edge is holding it out from threading, a little firm pressure as you turn it should help. It may help to hold the tab sticking down with a pair of vice grips for better purchase.
Jun 5, 2009 at 9:22 AM
