1995 Plymouth Voyager turn single
1995 PLYMOUTH VOYAGER
161,000 MILES • 6 CYL • 2WD • AUTOMATIC
VICTORLLL
  • 5 POSTS
once turn on the left side turn single the back up lights blink as well the right side dont dont it what is the problem i change all light bulbs relys brake lights work running lights just once you turn on left turn signel the back up light blink as well help
Sep 8, 2010 at 7:01 PM
CARADIODOC
  • 34,340 POSTS
Hi victorlll. Welcome to the forum. All of these lights share a common ground wire. When that wire is broken, current will still go through one bulb and find an alternate path to ground through the other bulbs. That makes them all light up but not at full brightness.
You can prove the wire is broken by removing the left backup bulb and the all of the bulbs on the right side. That will remove the alternate paths to ground and the left brake light will not work. If the left brake light still lights up but is very dim, current is likely going through the two license plate lamps to ground.
The black wire from each socket is the one to test for continuity to ground.
caradiodoc
Sep 8, 2010 at 7:40 PM
