1999 Plymouth Voyager Brake light does not work
1999 PLYMOUTH VOYAGER
125,000 MILES • 4 CYL • FWD • AUTOMATIC
CHERBIG
My left brake light is not working. I replaced the bulb but that wasn't the problem. Is there a fuse or relay that I could replace?
Oct 23, 2008 at 1:31 AM
  • 110,244 POSTS
Hi:
If the right brake light works, it isn't a fuse. They work from the same circuit. What you need to do is check the light socket for power when the brake is on. If there is power, replace the socket. If there is no power, you will need to trace the wire to find where the power is lost. There may be a broken or damaged wire.
Let me know if you have any other questions.
Nov 5, 2008 at 5:50 AM
