1995 Plymouth Voyager Oil Pressure Gauge
1995 PLYMOUTH VOYAGER
200,000 MILES • 6 CYL • FWD • AUTOMATIC
ERIFENBURG
When I put on the gas the oil pressure gauge goes up close to H but not into H. When I let off the gas it goes back to normal. Is this normal or could there be a problem with the oil sending unit or something else?
Dec 25, 2009 at 3:22 PM
Do you have any type of engine knocking noises if not check oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Dec 25, 2009 at 3:43 PM
