Plymouth Voyager, Mid-80's model - 90000 miles
2012 PLYMOUTH VOYAGER
RAYRED
On hot days the engine oil pressure gauge shows low pressure at idle - check gauges warning light illuminates.
Upon increasing rpm pressure increases and warning light goes off.
Could a thicker oil work, or should timing chain be tightened - if the latter, can it be done at home?
Thanks - Ray
Jul 15, 2007 at 6:36 PM
MERLIN2021
  • 17,250 POSTS
If the master is properly bench bled, you wont need to bleed the others...bench bleed master attach lines and bleed just the lines at master!
Jul 17, 2007 at 9:46 AM
