It it does that as soon as you put water in it where it comes out the exhaust then the problem is most likekly the head gasket or other internal problems. What happens when its cool and not running and yiou fill up the radiator then start the engine what does it do? Do you loose all the water out the tailpipe? If it does then I would look at the headgasket or something else internal.
SPONSORED LINKS
Saturday, May 9th, 2009 AT 9:31 PM
