1994 Plymouth Voyager need help fast
DARKNIGHT
  • 1994 PLYMOUTH VOYAGER
  • 6 CYL
  • 10,000 MILES
Yes I need help my starter is not working it will not start so I had it look at and it pass so I did the battury and the alltnator too and they pass so I did the stater rely and it was runing for a day then stop running I did the same thang and it all pass so do you know what I can do know?
Sunday, April 25th, 2010 AT 6:50 PM
2CARPRO JACK
  • 11,533 POSTS
You need to begin a thestarter, use a test light to see if it has power at the small wire when the key is in the crank position. If it hs power, the starter is bad, regardless of how it tested on the bench. Sometimes they will be ok for a while then fail suddenly. That is why it needs to be tested when it is in the vehicle, but not starting. Also try to start it in neutral instead of park to see if it will work.
Sunday, April 25th, 2010 AT 7:15 PM
