Are you sure it's a fuel issue? Can you check fuel pressure?
You should be able to check for codes by cycling the ignition switch. You turn the key till the dash lites come on, no further. Cycle the key on--off, on--off, on, then the cel starts flashing, you count the flashes to get the codes.
Did you check for spark at the plugs with the vehicle cranking?
SPONSORED LINKS
Monday, January 19th, 2009 AT 3:24 PM
