Engine Performance problem
1994 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
1994 Plymouth Voyager - 3.0L - 6 cylinder
Has very nasty knocking on acceleration, sometimes even light acceleration - using Top Tier fuels. Just changed out the O2 sensor a few weeks ago - that helped some but not completly. If I add fuel system cleaner it helps, but again, only for a little while. My mechanic wants to retart base timing. I want to get at the knock sensor and check it, but is there one on this vehicle - I keep getting conflicting information? Also, checked a spark plug - tips show proper color (light tan). Same mechanic has maintained van since I bought it used December 2006. Could it be an EGR system and if so, what do I check?
May 17, 2009 at 4:42 AM
