1994 Plymouth Voyager
STEPHENLWHITE
  • 1994 PLYMOUTH VOYAGER
1994 Plymouth Voyager 6 cyl Automatic
THE CAR WILL START FINE WHEN IT IS COOL, BUT IT WILL NOT START AFTER THE MOTOR WARMS UP. THE STARTER WILL TURN OVER, BUT IT WILL NOT START. WE TOOK IT TO A MECHANIC AND HE PUT A COIL ON IT. THIS DID NOT HELP IT. CAN YOU PLEASE HELP US?
Wednesday, December 30th, 2009 AT 10:07 PM
  • 109,885 POSTS
I will try my best to help. I need you to check two things. When the engine doesn't start, I need to know if you are getting spark and fuel to the engine. One will be missing.
Here are the how to's for checking. Check things out and let me know what you find. Remember, check it when is won't start.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Monday, January 4th, 2010 AT 2:36 PM
