1993 Plymouth Voyager oil leak
SSOUTHERTON
I have recently incountered a pretty bad oil leak on my 1993 plymouth voyager. Like one hour of driving on the freeway and i am out of oil and a knockin has started and it has 145,600 miles on it i replaced valve cover gaskets, oil pan gasket and i now have the whole rear side opened up thinking it was the front crank shaft seal but upon inspecting the seal it seems to be ok . But when i removed the timing belt cover the is oil pretty much all overbut i cant pin point where the leak is. could help me out with what other seals or gaskets i should check and replace while i have that opened up.Also the oil seems to be leaking above the crank shaft and a little to the right of the crank shaft towards the radator side.If you have any suggestions that would be great thank you very much
Mar 12, 2006 at 8:56 AM
RAYHUT
  • 134 POSTS
i hate to say it but...you might actually have to rebuild the whole motor to get it in running order again. sorry
Mar 12, 2006 at 7:51 PM
SSOUTHERTON
why would i have to rebuild the whole motor
Mar 12, 2006 at 11:42 PM
BILL8220
You didn.t specify engine size, but if you have a timing belt you have cam shaft oil seals. I would check them for oil leaks.
Mar 13, 2006 at 12:53 PM
OKHEDHER
  • 6 POSTS
dear go and change the seal between the gear box and engine and the convector seal that's it i've the same plymouth acclaim 94 130000km
Mar 13, 2006 at 7:23 PM
SSOUTHERTON
the plymouth voyager has the 3.0 is that the same motor in your acclaim if so you had the same problem with the oil leaking???????????????
Mar 16, 2006 at 9:35 AM
