1993 Plymouth Voyager Car Won't Start
ARN C.
  • 1993 PLYMOUTH VOYAGER
1993 Plymouth Voyager 4 cyl Two Wheel Drive Automatic
I tried starting my car after work and it was a bit sluggish in starting(first time ever). I drove home, next morning I tried to start it and nothing. I had the battery checked and it is fine. I rapped on the starter with a small hammer and I did get a click. But still won't start. Any suggestions? Is it the starter or starter solenoid that is attached to the starter? Or is there something else I should try or look for?
If you may think it is the starter, could you tell me the procedure for replacing it?
Thanks
Arn C.
Saturday, September 20th, 2008 AT 3:59 PM
BMRFIXIT
  • 19,053 POSTS
CHECK FOR POWER AT THE STARTER
CHECK SMALL WIRE FOR POWER WHEN TRYING TO START
replace starter
make sure u disconnect battery terminal and set aside
disconnect wires and then starter bolts
not a bad job to do
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, September 24th, 2008 AT 1:14 PM
