1992 Plymouth Voyager no fuel
EJOHNSTON
  • 1992 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 140,000 MILES
My van is not getting any fuel. Where to start and are thier any relays to the fuel system? HELP can not get to work without wheels have 4 kids!
Sunday, May 17th, 2009 AT 1:40 PM
  • 109,867 POSTS
There is a fuel pump relay under the hood in the power distribution center. You can try that. If it doesn't help, you will need to remove the fuel tank and check to see if you are getting power to the pump. If there is power, chances are the pump is bad.
Monday, May 25th, 2009 AT 8:17 PM
