Hello, You might try to retrieve trouble codes, by cycling the ignition switch, on--off, on---off, on, engine not running, you don't crank it. If the check engine lite starts flashing, count the flashes to get the codes.
Also, use a fuel pressure gage, check fuel pressure.
SPONSORED LINKS
Friday, August 14th, 2009 AT 12:26 PM
