1989 Plymouth Voyager oil presher
WBOUTS
  • 1989 PLYMOUTH VOYAGER
1989 Plymouth Voyager 6 cyl 200000 miles
When I stop at lights my check gauges light comes on and when I make a turn my oil gauge drops all the way
Wednesday, September 8th, 2010 AT 7:55 AM
WRENCHTECH
  • 20,761 POSTS
With that kind of mileage you probably just have a worn out engine. It's really not worth investing in at this point. It's already given a life's worth.
Wednesday, September 8th, 2010 AT 8:39 AM
CARADIODOC
  • 34,367 POSTS
Hi wbouts. Welcome to the forum. Have you checked the oil level? Which engine do you have? With the 3.0L engine, 6 pounds of pressure at idle is acceptable and the sending unit is calibrated for that value. For the 3.3L, that is way too low. The 3.3L did have a lot of trouble with the sending units. The clue is the oil gauge reading will vary up and down while you're driving at a steady speed.
The place to start is by having the pressure checked with a mechanical gauge to find out if the problem is with the sending unit or in the engine. At the mileage you listed, you may have worn crankshaft and connecting rod bearings that are allowing excessive internal oil leakage. Ignoring them will lead to much bigger problems very soon. If the oil pressure is indeed low at idle but comes back up at higher engine speeds, you might get away with having those bearings replaced. I did that years ago on my '88 Grand Caravan with the 3.0L engine while looking for a different problem. It has 379,000 miles now. It only takes a couple of hours to replace those bearings when the vehicle is on a hoist.
Caradiodoc
Wednesday, September 8th, 2010 AT 8:43 AM
