1993 Plymouth Voyager Check gauges light on
SHKEVIANEGRON
1993 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
My check gauges light is on and none of the gauges on the dash work. I disconnected the battery and checked all the fuses in the fuse box on the driver side..What can i do to fix this problem?
Nov 3, 2010 at 10:54 AM
LEGITIMATE007
  • 5,121 POSTS
you will need to check the dimmer switch and then the body control module for a short, I had this same problem , on the same vehicle, and I found that the body control module had a couple of corroded connections, I pulled them out of their connections, scraped the wire so that it would make a better connection and it was fixed, I could see which connections where corroded just from looking closely at them.
Nov 4, 2010 at 6:05 AM
