Every once in a while, while driving along, it stalls. No warning, no roughness - the engine just stops running. We've taken long trips where it has never happened, or it can happen a couple of times on a short trip. It usually starts back up easily, but a couple of times it has been tough to restart. Once in a while it gives a little trouble when first started too. Letting it sit for a while seems to make a restart easy.
The check engine light does not come on.
The dealer found the hose to the fuel pressure regulator was off, but replacing it didn't help.
They suggest cleaning the idle-control motor, but are concerned with removing it without damaging the trottle body. As an alternative, they suggest a fuel injector cleaning might clean the idle control motor some.
Anyway, I hate to just throw money at an old car and am eager to get some suggestions about the problem.
Thanks!
Clear skies, Alan
SPONSORED LINKS
Friday, June 8th, 2007 AT 10:45 AM
