1991 Plymouth Voyager Engine Shut Down
193,000 MILES • 6 CYL • FWD • AUTOMATIC
LISIA
Would low oil cause the engine to shut down? The motor still turns over, but there is no spark. The dipstick reads very low oil. What can casue the shut down and how do I fix it?
Feb 28, 2008 at 2:36 PM
BMRFIXIT
  • 19,053 POSTS
low oil will not cause a no start or a shut off
don’t run engine low on oil or will be damaged
crank sensor would
check ? replace crank sensor
check ASD relay
Mar 3, 2008 at 9:59 AM
LISIA
The van leaks oil like crazy. Added oil, tried turning it over obviously still no spark, but the oil poors out the bottom near or around the oil filter.
Ideas on that?
Mar 3, 2008 at 1:23 PM
BMRFIXIT
  • 19,053 POSTS
you need to have that van started 1st .
but you may check oil pressure switch for oil leaks
Mar 3, 2008 at 11:04 PM
LISIA
I was driving the van when it died...never to start again. What and wher is the ASD relay, and Crank sensor.
Thanks
Mar 4, 2008 at 3:09 AM
BMRFIXIT
  • 19,053 POSTS
you need to check for spark and fuel pressure
when key is on do you hear the fuel pump running?
check timing belt depend on your engine size if you have one
fuel pump more likely to be the cause
engine size ???
Mar 4, 2008 at 4:59 AM
