1993 Plymouth Sundance Noises, shakes and smells (oh my)
1993 PLYMOUTH SUNDANCE
80,000 MILES • 4 CYL • 4WD • AUTOMATIC
PARA
I dont know much about cars. I have a 93 plymouth sundance, that when I accelerate past 30 mph starts shaking and hesitates to go any faster. It also has started making a strange noise, and when I parked the car bc it sounded like the tire had actually gone flat, the right side of the car smelled like something was burning.
Jun 12, 2009 at 10:43 AM
CARADIODOC
  • 34,381 POSTS
Sticking front brake caliper. The caliper could have a buildup of rust pits or dirt on the piston. This will not cause a problem until new brake pads are installed and the pistons are retracted to make room for them.
Another somewhat common problem is a restricted rubber brake hose. Rust builds up inside the crimp where the metal bracket holds the center of the hose. The crimp can be opened up slightly with a channel lock pliers.
caradiodoc
Jun 19, 2009 at 12:44 PM
