Hi there,
The first thing to do is check for any set engine fault codes, also just check for spark and injector pulse, if you can also check for fuel pressure, if not your mechanic can do these tests for you and advise on what to do next when a fault is located.
Mark (mhpautos)
SPONSORED LINKS
Monday, April 28th, 2008 AT 4:11 AM
