1995 Other Plymouth Models
1995 PLYMOUTH
STEWY2424
Transmission problem
1995 Other Plymouth Models 4 cyl Automatic
why would a trans service make the trans not work ( like go into gear from a stop?)
Apr 16, 2008 at 1:12 PM
SERVICE WRITER
  • 9,123 POSTS
Couple reasons. Not enough or wrong fluid.
There was already a problem present that was a breath away from happening, and the service pushed the weak link over the edge. That's why there are times when going in to a transmission to replace one wear part is not always possible as there are enough other wear parts that are borderline or bad once it is opened up resulting in a rebuild.
Apr 16, 2008 at 1:15 PM
STEWY2424
thank you very much
Apr 16, 2008 at 1:31 PM
