1993 Other Plymouth Models Car lurches when cold
1993 PLYMOUTH
175,000 MILES • 4 CYL • FWD • MANUAL
JADES976
  • 5 POSTS
I have a 1993 Plymouth Laser. It is a 1.8L, 4-cyl, 5-speed manual. I just replace the transmission with one from a junkyard. The other transmission had a hole in the case and had lost 5th gear. The care drove normal other than the fact that I didn't have 5th gear. After I replaced the transmission, the car now lurches in first and second gear when the car is cold. It also lacks power in first. What could be wrong? The only thing that has changed is the transmission and the gear oil. I am using the recomended type and viscosity for the climate. Should I go to a thinner oil?
Feb 25, 2008 at 2:00 AM
  • 110,244 POSTS
Hi:
Has the check engine light come on? Also, check closely that you didn't disconnect any wires or vacuum lines when you were working. It is easy to have happen.
Let me know what you find.
Mar 17, 2009 at 12:51 AM
