Hi, thanx for the donation. Yeah, a flashing light is usually an indication of a misfire, now a misfire can mean many things, however in your case I think that you, have a problem with the idle air control valve and possibly a dirty throttle body, that is mostlikely why your stalling. The misfire can also be contributed in part by that valve, (air restriction). Two, the other part, is your suffering from a bad intake manifold gasket, a hole in the "accordian" air intake tube coming from the air filter box to the throttlebody, a bad injector or egr valve. These are some of the common causes of a misfire. I'm sorry that we cant narrow it down, but that is the bad part of a misfire. All those other items that you replaced, were also possibilities, atleast those are taken care of. Let me know if you have any more questions,
jody
SPONSORED LINKS
Tuesday, May 18th, 2010 AT 3:55 PM
