1999 Plymouth Breeze Bubbling Noise
JEANNETTE
I purchased a 1999 plymouth breeze 4 months ago it had 58,000 miles on it. It now has 65,000 miles and has started to make bubbling noises coming from the hood of the car. The thing is, the bubbling noise continues after the car has been turned off. What could this be and how could I fix the problem. Thank you,
Jeannette
Jun 7, 2006 at 9:56 AM
KILLZODIAK
  • 13 POSTS
next time when you hear the bubbling pull over and look under the hood. look at the radiator backup or whatever its called. its where you put water that gets sucked into the radiator. most likely the water lvl is getting low in the radiator and it is boiling back into the reservior. if the car is getting really hot or if you live in a desert where the temp gets above 100 in a day then most likely you need to flush the radiator and add freon and water.
Jun 8, 2006 at 7:05 AM
THOMAS29
  • 6 POSTS
my car makes the same bubbling sound. i dont live in a hot area and it does it even in the winter, its not over heating. did you ever figure out what the problem is?
Dec 6, 2008 at 9:15 AM
BMRFIXIT
  • 19,053 POSTS
If the bubbling under the hood need to check if the coolant fan coming on( when needed )
check coolant level and thermostat
have the head gasket checked and tested good luck
Dec 6, 2008 at 9:30 AM
Suggested Repair
Check that the coolant fan comes on when needed, verify the coolant level, and inspect the thermostat. Have the head gasket tested.
Conversation Summary
The owner of a 1999 Plymouth Breeze reported bubbling noises from under the hood that continued after the engine was shut off. A user suggested low coolant boiling back into the reservoir. The expert advised checking cooling-fan operation, coolant level, and the thermostat, and having the head gasket tested.
