1996 Plymouth Breeze Acceleration Whine
BREEZY WEEZY
I have a 1996 Plymouth Breeze 2.0L Automatic with 158800 miles. My question is this....it makes a wooring sound when it starts and gets louder as I accelerate. The car has been wrecked in the front end and repaired. I've had problems with power steering in the past but haven't had problems lately. I replaced the alternator thinking that was the problem, but it is still whining and seems to be a little louder now. Would the belt be causing this or maybe the air conditioning pulley? a friend mentioned bearings? As a female I have some knowledge in cars, but sure could use some help on this one! :?
Jun 3, 2007 at 6:48 AM
SERVICE WRITER
  • 9,123 POSTS
Could be wheel bearings, could be choppy tire wear, could be a pulley. IF the noise changes when turning one way or the other, i would suspect bearings. IF the noise is present when at idle and pitch changes as accelerator is pressed, I would suspect a pulley.
If you run your hand around the tread of the tires, it should be smooth, not choppy or sawtoothed etc.
Jun 3, 2007 at 11:51 AM
Suggested Repair
Diagnose the whine by when it changes. Suspect a wheel bearing if the noise changes when turning one way or the other. Suspect an accessory pulley if the noise is present at idle and its pitch rises as the accelerator is pressed. Also run a hand around the tire treads and check for choppy or sawtooth wear.
Conversation Summary
The owner of a 1996 Plymouth Breeze 2.0L automatic reports a whining sound that starts with the engine and gets louder during acceleration. The car was previously wrecked and repaired in the front, and past power-steering problems have not recently returned. Replacing the alternator did not stop the noise and it may be slightly louder. The expert says the cause could be a wheel bearing, choppy tire wear, or a pulley, and recommends checking whether the noise changes while turning, whether its pitch changes with acceleration, and whether the tire treads are smooth.
