2000 Plymouth Breeze Battery
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
POERMAN
Where is the battery located? I found the jump start termnals but don't see the battery to remove for new one.
May 16, 2010 at 7:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
to get to the battery first turn the steering wheel as far as you can to the left. In front of the RF tire in the wheel-well is a plastic cover with 5 tabs across the top and side. Turn these 1/4 turn to the left, and the panel pulls off. Use a 1/2 inch socket to remove the battery mount/hold down. It would be best to remove the top bolt first. Then use a 5/16 inch socket to remove the front mount battery cables, and the battery will slide right out. You may have to lift the car a bit to get the battery out.
May 16, 2010 at 9:07 AM
