my car started to jump rpms and then it just wouldn't shift what could be the problem
Nov 19, 2009 at 12:28 PM
✓Experienced Mechanic
When you say it started to jump, was the trans slipping? Also, has the check engine light come on? There is a trans module that controls it and if it is causing the problem, the light should be on.
