1999 Plymouth Breeze Shuts down
100,535 MILES • 4 CYL • FWD • AUTOMATIC
CASNET
I have a 99 Plymouth Breeze. I just bought it uses...
It runs perfect for a while. After it gets up to running temp. every 3 to 4 min is just shuts down. It may or may not buck once or twice, like it isn't getting gas, then completely dies. As soon as I turn off the key wait about 30 second, it starts right back up as if nothing was wrong and runs perfect for another 3-5 minutes then does the whole thing over again. I replace the upstream O2 sensor and the fuel filter. It still does it. If I disconnect the O2 sensor it runs fine without any problems. It is not showing any codes until I run without the O2 sensor connected then I only get the code for the sensor not working
Apr 13, 2008 at 11:31 AM
BMRFIXIT
  • 19,053 POSTS
I would start checking relays
and then put spark tester on it
check also the crank sensor
Apr 21, 2008 at 11:28 AM
SL1M
I also have a Breeze that is doing the same thing. It runs for about 8 to 10 minutes then begins to just shut off. I wait about 30 to 60 seconds then start the car and drive. It will only run for about a minute or two more then shuts down. Is there any other info anybody can offer up?
Aug 31, 2008 at 11:50 PM
BMRFIXIT
  • 19,053 POSTS
CHECK fuel pump and fuel pressure
check for spark
no spark check ASD relay and crank sensor
check for codes
cycle key ON OFF ON OFF ON
Sep 1, 2008 at 12:31 AM
