1998 Plymouth Breeze Power Windows
1998 PLYMOUTH BREEZE
153,107 MILES • 4 CYL • 4WD • AUTOMATIC
IVANPERRY
My power window on the driver's side began working off and on intermittantly about a month ago, and now no longer works. The other 3 windows still work with no problems. Is there a fuse that needs to be replaced on the window to make it work, or is the job more complicated? What needs to be done to fix this problem?
Aug 30, 2010 at 11:13 AM
SATURNTECH9
  • 30,869 POSTS
Your going to have to pull the door panel off the door that doesn't work and see if you have power and ground to the motor when the switch is pushed.If you do then you have a bad motor or a binding window glass.
Aug 30, 2010 at 11:34 AM
