1998 Plymouth Breeze No brakes at all after changing calipe
1998 PLYMOUTH BREEZE
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
DBMCINNIS
Brakes were spongy and master cylinder dirty. So I changed master cylinder (used old resevoir) - bench bled. Brakes were more spongy (but worked some) and front brakes bleeder screws frozen. So I changed front calipers and bled all 4 brakes (in proper order). Brakes don't work at all now! Can't even risk putting in gear now because can't stop.
When engine off there is initial resistance with pedal depression (but goes all the way down easily). With engine on no resistance at all. In vehicle bleeding of master cylinder hasn't helped.
Dalton McInnis
dbmcinnis@fastmail.fm
Aug 19, 2010 at 7:06 AM
WRENCHTECH
  • 20,761 POSTS
Take a look at your front calipers and tell me if the brake bleeders are at the top or the bottom.
Aug 19, 2010 at 7:32 AM
DBMCINNIS
Both are on top. Did I put them on backwards? I mean a "left" caliper or the rt front wheel and a "right" caliper on the lt front wheel?
Dalton
Aug 19, 2010 at 9:59 AM
DBMCINNIS
After my quick answer, I actually did what you asked and looked at the caliper. It appears that the bleeders are on the bottom. I will upload a picture. Dalton
https://images.2carpros.com/forum/automotive_pictures/563324_caliper_1.jpg
Aug 19, 2010 at 10:19 AM
WRENCHTECH
  • 20,761 POSTS
Deleted
Aug 19, 2010 at 10:20 AM
WRENCHTECH
  • 20,761 POSTS
OK, you DO have them on the wrong side and they will never bleed that way. Switch sides and you'll be fine.
Aug 19, 2010 at 10:21 AM
DBMCINNIS
I'm sure going to remember (and recommend) this site. Thanks again.
Aug 21, 2010 at 12:56 PM
WRENCHTECH
  • 20,761 POSTS
Thank you, glad we could help.
Please leave feedback if you haven't already.
Aug 21, 2010 at 1:45 PM
