Your vehicle's engine is fuel injected and should not require starter fluid to start. It is a lot different and much more dangerous using starter fluid on a fuel injected vehicle than it is on the older carburator style engines. If you absolutely want to use it than spray it in the throttle body or as close as possible.
SPONSORED LINKS
Thursday, October 21st, 2010 AT 9:22 PM
