1997 Plymouth Breeze My car wont start!
RACHELLYNN1986
  • 1997 PLYMOUTH BREEZE
  • 4 CYL
  • 4WD
  • 198,000 MILES
It was in accident. Everything was fixed. But now the car is having a hard time turning over. First it kept blowing fuses so we changed them. Finally it stopped blowing the fuses an now it just wont start at all. Its makes a clicking noise when you turn the key over. But it wont turn the engine over. I really just need a quick fix solution so I can get it to start. Could it be the starter or the relay fuse switch thing or even the solenoid?
Someone please help. Thanks
Friday, February 5th, 2010 AT 8:12 AM
JDL
  • 16,098 POSTS
Hi, I'd have to make sure the battery has a full charge and the connections are good. Next, I'd check the circuits at the starter relay, underhood power distribution center. If that checks out, I'd check the starter. Some of the national brand autostores will check the starter, but, you have to take it off and take it to them.
Friday, February 5th, 2010 AT 2:07 PM
